DIAdem
can't open clipboard
I have been getting an error message during processing indicating Diadem can't opne the clipboard.  Is there a command that I can execute within VBS to fix this problem?
Thanks!
Tom
(4,220 Views)
Hi Tom,
I'm not familiar with this error.  Would you please post the entire error message as well as the line of VBScript code that caused the error?  What version of DIAdem are you using?  What is your VBScript doing?  There are usually alternatives to using the clipboard programmatically in DIAdem.
Brad Turpin
DIAdem Product Support Engineer
(4,194 Views)
Hello Brad!
You should find this behaviour in the NI bug database. I reported it many years ago and recalled it several times with no result. R&D should know it.
My workaround was build in a high level language and added to DIAdem via GPI.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,189 Views)
