DIAdem
can't open nested non-modal dialog
I'm using 2 nested non-modal dialogs (Diadem 11) named "Dlg_Menu" and "Dlg_Liste"
' The main non-modal dialog "Dlg_Menu" works fine. I can open it !
Dim MyDlgMenu
Call SUDDefLoad("dlgImpedance.SUD")
If Nothing is SudNonModalDlgLst("Dlg_Menu") Then
Set MyDlgMenu = SudDlgCreate("Dlg_Menu")
Else
Set MyDlgMenu = SudNonModalDlgLst("Dlg_Menu")
End If
MyDlgMenu.Show
MyDlgMenu.Activate
' I want to open the second nested non-modal named "Dlg_Liste" via control button defined in "Dlg_Menu" but it bugs !
dim MyDlgListe
Sub BtListe_EventClick()
Dim This : Set This = BtListe
If Nothing is SudNonModalDlgLst("Dlg_Liste") Then
Set MyDlgListe = SudDlgCreate("Dlg_Liste")
Else
Set MyDlgListe = SudNonModalDlgLst("Dlg_Liste")
End If
MyDlgListe.Show
End Sub
Error occured when executing the dialog box "Dlg_liste" !!!!
Thank you in advance
Helion Fuelcells / Aix en Provence
(4,144 Views)
Hi Andre,
This should work, but you should always use SudDlgCreate() when launching non-modal SUDialogs.  The SudDefLoad() command stores the full file path to THAT SUDialog in an internal variable, which can mess up subsequent non-modal SUDialog callbacks.
Brad Turpin
DIAdem Product Support Engineer
(4,124 Views)
Hi Brad !
Thank you for your active helps !
It works fine now ! ...
In parallel the trouble was related to an event occuring when I open the 2nd non-modal dialog (Dlg_Liste).
Another question : The non-modal dialog don't have  "minimize" and "maximize" windows controls ?
Thank you again !
Andre Rako / Helion Fuelcells Hydrogen Power/ Aix en Provence (Fr)
(4,112 Views)
