DIAdem
cannot interpret the selected character
Hi all,
I'm trying to solve a problem using Diadem Reports.
My script loads a .tdr file and puts some signals in a 2D axis system.
I use manual scaling for Y Axis and I want that the Begin and End value are taken from the script.
After having watched a manual,  I've tried to set up a user command called XScaleMaxVal and I've written this thing in the End field:
@@XScaleMaxVal(Max)@@          where Max is the max value that the script has calculated
It gives me this error:
Does someone have an idea of what can I do?
I think I could also avoid to set the user command and writing only @@Max@@
But it gives me that error
Best regards
(4,886 Views)
Ok, solved in this way:
Call PicLoad("C:\temp\CrashAnalysis\prove\LayoutProva.TDR")
    Call GraphObjOpen("2DAxis1")
    Call GraphObjOpen(D2AxisYObj(1))           'here I select the Y1axis
    D2AxisYScaleType="manual"                        ' here I set manual mode for scaling
    D2AxisYEnd = AcXMax_                                  ' I set the correct values
    D2AxisYBegin = AcXMin_
    D2AxisYOrigin = AcXMin_
    D2AxisYTick = 100
    Call GraphObjClose(D2AxisYObj(1))
    Call GraphObjClose("2DAxis1")
    Call PicUpdate()                                               'I close the object
    Call GraphObjOpen("2DAxis1")                    'I reopen it to create the curves
    Call GraphObjNew("2D-Curve","Curve1")  'Creates a new curve
    Call GraphObjOpen("Curve1")            'Opens curve object
    'D2CCHNX          ="Time"    'Defines x-channel
    D2CCHNY          ="15TUNNRELO01ACXP"   'Defines y-channel
    D2CAXISPAIRNO    =1
    D2CURVECOLOR     ="red"
    Call GraphObjClose("Curve1")
    Call PicUpdate()
(4,853 Views)
