DIAdem
cannot save the layout correctly
I'm getting the message 'Cannot Save the Layout Correctly' when I try to save a report in DIAdem 11.0 and the TDR file does not save.
Any ideas what can cause this and any solutions?
(3,877 Views)
Hi RLH,
No, I've never heard of that issue before.  Was DIAdem working correctly for you at an earlier time?  If so, what changed on the computer from then to now?  Can you export a PDF file or a JPG image from the REPORT File menu?
Please post a screenshot of the error,
Brad Turpin
DIAdem Product Support Engineer
(3,867 Views)
Yes I could export a pdf; which meant I didn't loose everything.
I seem to have resolved this problem at the moment by shutting down DIAdem and restarting.
Thanks for your help.
(3,865 Views)
