DIAdem
cfc FILTERS
Can any one tell me whether the CFC filters SAEJ211 comes as a part of  DIAdem Basic version or Crash analysis toolkit..
(4,391 Views)
Accepted by topic author Rash.patel
Hello Rash,
The CFC filters are part of the Crash Analysis Toolkit, which can be added to the Base, Advanced and Professional versions of DIAdem.
Hope that helps,
     Otmar
Otmar D. Foehner
(4,380 Views)
Hi otmar,
Thanks for your reply.
But if I write a code in Diadem Advanced which uses CFC  filters, and after that If i try to run that code in Diadem Basic , will this basic version can be able to understands those CFCfilters ?? Because in the link mentioned below you can see Basic doesnt includes digital filters in it.
So whats the solution? Please let me know if any one of you are aware.
https://www.ni.com/en/solutions/transportation/case-studies/diadem-software-accelerates-crash-test-a...
(4,372 Views)
Hello Rash,
Any Script created in either DIAdem Advanced or Professional can be run in DIAdem Base without restrictions. DIAdem Base doesn't provide access to the dialogs of the advanced and professional functions, but it will run those functions when used within a Script.
Hope that helps,
    Otmar
Otmar D. Foehner
(4,370 Views)
