DIAdem
changing font of a report TextObject
in many reports I have the same TextObject1 (a small table).
how can i change the font of this table to Arial by script?
(3,094 Views)
Hi Trader,
You can only edit the Text Object in DIAdem at design-time, not during run-time.  You could perhaps store several different versions of the sheet this Text Object is on, each in a different *.TDR file and each with a different font configured.  Then your Script could conditionally append-load the correct sheet to give you programmatic flexibility.  Or you could consider using a 2D table object instead.
Brad Turpin
DIAdem Product Support Engineer
(3,063 Views)
Tanks.
That means in DIAdem it is not posible to change it with a script directly.
(3,056 Views)
Hi Trader,
The only way I know how to affect the text object with a script is to change the value of a Data Portal property or global variable that is accessed with @@ expressions inside the static configuration of the text object.
Brad Turpin
(3,048 Views)
