DIAdem
changing labels on y axis
I am using the NoName "template" in data portal that a previous employee has set up to display four seperate 2d graphs with marked axis. How can I change the axis labels?
(3,683 Views)
The labels on the axes are by default using the names of the X or Y channel that is used in the particular axis system. The default variable referenmces inside an axis label is:
@CN(CCN)@ [@cd(CCN)@]
@ = This tells DIAdem that a variable follows
CN = Channel Name
CCN = Current Channel Number (number of the channel used for the axis)
CD = Channel Dimension or Unit
The result of the above combination of variables looks like this on an axis:
Time [s]
To change the axis labels, double click onto the label you wish to change and enter the new label you wish to use in the text field inside the dialog that appears. You can use any text or combination of variables and text for this prupose.
Please let me know if you require more inform
ation.
Otmar
Otmar D. Foehner
(3,683 Views)
