DIAdem
channel mark peak report
Hy,
I want to ask, how you can mark a point in a curve on the report.
I analyze some curves, I take a peak from the curve and I want to mark the peak to be seen on report.
Somethink like a point and some lines to the X and Y axes, to see the coordonates too.
I use a script to load the data and make the report, soo I need a  VBS command.
Thank you.
(3,828 Views)
Accepted by topic author Marse
Hi Marse,
The simplest solution would be to create a "PeakX" and a "PeakY" channel and add a new curve configuration to plot this XY curve with no lines and only markers.  If there is only 1 value in each of these channels, then you will only get one marker exactly at that peak.  If you used the DIAdem peak finding function to determine your peak, then you probably already have the X and Y peak channels.
Ask if you have additional questions,
Brad Turpin
DIAdem Product Support Egngineer
(3,820 Views)
