DIAdem
channel sorting
Uperbound*
Message 11 of 20
(2,208 Views)
hey,
you could do something like this:
dim group
dim channel
for each group in Data.Root.ChannelGroups
    for each channel in group.Channels
        Call Area.DisplayObj.Curves2D.Add("[1]/Time",group.Name&"/"&channel.name)
    next
next
Britton C.
Senior Software Engineer
Message 12 of 20
(2,194 Views)
That did not work, I would prefer to just have a wild card for the number in the for section. like for i = 1 to -1 or something like that.
Message 13 of 20
(2,192 Views)
for i = 1 to Data.Root.ChannelGroups.Count
Message 14 of 20
(2,176 Views)
Thank you , I tried:
For i = 1 to GroupCount and that seems to be working.
Message 15 of 20
(2,172 Views)
Is there any way to make these channels wild card?
For i = 1 To GroupCount
Call Area.DisplayObj.Curves2D.Add("[1]/Timesec","["&i&"]/U_FREXG")
Call Area2.DisplayObj.Curves2D.Add("[1]/Timesec","["&i&"]/B1COH0")
Call Area3.DisplayObj.Curves2D.Add("[1]/Timesec","["&i&"]/B1THC0")
Call Area3a.DisplayObj.Curves2D.Add("[1]/Timesec","["&i&"]/B1NOx0"
Like B1NOx* or &B1Nox&
I have analyzers in different positions, so they would not always be in position 0.
Thank you in advance.
Message 16 of 20
(2,111 Views)
Hi REX,
You can use the "*" symbol anywhere in the channel path to allow wildcard matching.  DIAdem will display the first channel it finds that satisfies your wildcarded channel path.
Call Area.DisplayObj.Curves2D.Add("[1]/Timesec","*/U_FREXG")
Call Area2.DisplayObj.Curves2D.Add("[1]/Timesec","["&i&"]/B1COH*")
Call Area3.DisplayObj.Curves2D.Add("[1]/Timesec","["&i&"]/B*THC*")
Call Area3a.DisplayObj.Curves2D.Add("[1]/Timesec","["&i&"]/*B1NOx*"
This feature was not always in DIAdem, so if you have a particularly old DIAdem version you will not be able to use wildcard characters (* or ?) in the channel path.
Brad Turpin
Message 17 of 20
(2,108 Views)
We use 2014 version, and it does not seem to work, is there a particular version we would need?
Thank you.
Message 18 of 20
(2,100 Views)
Hi REX,
I'm sorry, the wildcarding I described only works directly in a REPORT layout. I didn't notice that your script had an "Area" parent object, which means you're wanting to do this in VIEW.  In this case, you'll need to apply the wildcards in two steps: first find the channel, then assign that channel to the VIEW Area graph:
Set Channel1 = Data.GetChannel("*/U_FREXG")
Set Channel2 = Data.GetChannel("["&i&"]/B1COH*")
Set Channel3 = Data.GetChannel("["&i&"]/B*THC*")
Set Channel4 = Data.GetChannel("["&i&"]/*B1NOx*")
Call Area1.DisplayObj.Curves2D.Add("[1]/Timesec", Channel1.GetReference(eRefTypeIndexName))
Call Area2.DisplayObj.Curves2D.Add("[1]/Timesec", Channel2.GetReference(eRefTypeIndexName))
Call Area3.DisplayObj.Curves2D.Add("[1]/Timesec", Channel3.GetReference(eRefTypeIndexName))
Call Area4.DisplayObj.Curves2D.Add("[1]/Timesec", Channel4.GetReference(eRefTypeIndexName))
Brad Turpin
Message 19 of 20
(2,093 Views)
Thank you, I appreciate your help.
Message 20 of 20
(2,090 Views)
