DIAdem
check if excel file open
Hallo,
how can i check if a excel file is open or not open. I need a code for the diadem script.
thanks
(3,921 Views)
Accepted by topic author Joediadem
You can use code like this to make sure that a file is accessible exclusively.
Option Explicit
dim xlsxFile : xlsxFile = "C:\temp\out_EXPORT.xlsx"
MsgBox FileAccessible(xlsxFile)
function FileAccessible(byref filePath)
  FileAccessible = FALSE
  dim fh : fh = TextFileOpen(filePath, eTextFileAttributeExclusive OR eTextFileAttributeRead OR eTextFileAttributeANSI)
  if -1 <> fh then
    call TextFileClose(fh)
    FileAccessible = TRUE
  end if
end function
(3,912 Views)
perfect, thank you
(3,889 Views)
