DIAdem
convert channel display format from time to numeric in a script
I am trying to convert the Display format of a channel that contains time values (mm/dd/yyyy hh:nn:ss.ffff) from Time to Numeric. I know I can do this in the properties section of the data portal but I would like to do it in a script. I want to be able to automatically convert it without having to manually do it each time I import new data. What syntax is needed for this?
I've already tried the ChnPropSet (and ChnPropValSet) commands but it doesn't change the Display format after I run the script. Thanks for all your help.
(6,557 Views)
Hi Steinmeister,
i've found a way. You can use the "ChnCalculate"-Function but you must store it to a new channel.
Dim oGrp, oChn
Dim sChn
'iterate over all channels
For Each oGrp In Data.Root.ChannelGroups
  For Each oChn In oGrp.Channels
    sChn = transformTimeChnToNum(oChn)
    If (sChn <> "") Then
      Call ChnCopy(oGrp.Name & "/" & sChn, oGrp.Name & "/" & oChn.Name)
      Call ChnDel(oGrp.Name & "/" & sChn)
    End If
'function for transforming the channel
Function transformTimeChnToNum(oChannel)
  transformTimeChnToNum = ""
  If (oChannel.DataType <> DataTypeChnDate) Then
    Exit Function
  End If
  transformTimeChnToNum = oChannel.Name & "_num"
  Call ChnCalculate("Ch(""" & oChannel.ChannelGroup.Name & "/" & transformTimeChnToNum & """)=Val(Ch(""" & oChannel.ChannelGroup.Name & "/" & oChannel.Name & """))")
End Function
(6,541 Views)
Accepted by topic author steinmeister85
Data.Root.ChannelGroups(1).Channels("Zeit").Properties("displaytype").Value = "time"
Data.Root.ChannelGroups(1).Channels("Zeit").Properties("displaytype").Value = "numeric"
 For me the two lines switch the type. Be aware that the property is "displaytype" not the localized GUI name.
You can determine the name of a property by drag and drop it into the DIAdem script editor.
(6,540 Views)
I was mistaking "displaytype" with "datatype" 🙂
(6,537 Views)
AndreasK,
That worked perfectly. Thanks for the tip of dragging properties into the script editor and thanks for your help.
(6,515 Views)
