DIAdem
create tables of variables in Diadem Report.
is there a way to do the same thing with the python engine?
Message 11 of 14
(1,278 Views)
Hi Carlos,
Should be able to, but I have not actually tried it.
Paul
Message 12 of 14
(1,273 Views)
Hi Carlos,
Yes, this is how you elevate a python array to global status in DIAdem-- by creating an empty global variable and then assigning the python array variable to it:
string_array = []
string_array.append("value0")
string_array.append("value1")
string_array.append("value2")
string_array.append("value3")
string_array.append("value4")
dd.GlobalDim("MyStringArray")
dd.MyStringArray = string_array
You still end up with a global VBScript array, but it can be easily filled by python code.  I'm including the python script and the TDR file that references the global "MyStringArray" variable in a table and a text box.
Brad Turpin
Principal Technical Support Engineer
NI
Message 13 of 14
(1,264 Views)
Thank you Brad, this is really useful and it works.
Message 14 of 14
(1,249 Views)
