DIAdem
creating an excel concatenated if statement in diadem calculator
I am trying to create an equilivant to excel's 'concatenated if' function in diadem which will check a value of either 0,1,2 in one existing channel and apply a conversion of divide by 1,10 or 100 to another existing channel and creating a new channel with the resulting data.
Any help would be appreciated.
(4,690 Views)
Hello Adek!
The generic approach looks like this:
Call ChnCalculate("Ch(""Result"") = Ch(""Values"") / Array(1,10,100)(Ch(""Index""))")
Assuming 'Values' is your values channel name and 'index' is the index channel name with the 0/1/2 values.
If it is just the calculation you described you can also use a little bit mathematics:
Call ChnCalculate("Ch(""Result2"") = Ch(""Values"") / 10^(Ch(""Index""))")
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,687 Views)
Hello Matthias,
Thanks for the information, just to confirm, the excel function I am trying to replicate is :
Cell C2 =IF(Cell A2=0,Cell B2/1,IF(Cell A2=1,Cell B2/10,IF(Cell A2=2,Cell B2/100,Cell B2)))
Repeated for the whole channel length.
Therefore two channels A and B with the data and a new created channel C which is the result of the function
Maybe more of a nested function than concatenated perhaps.
Will your solution give me this result ?
Ade
(4,681 Views)
Hello Ade!
The ChnCalculate will do the calculation for the whole channels. Just give it a try: Make some short channels and run the command. You will seeSmiley Happy
Matthias
Matthias Alleweldt
Twigeater?
(4,679 Views)
Thanks Matthias,
I will give it a try.
Ade
(4,676 Views)
Hi adek (and others),
Just a quick note for the future.  R&D is actively working on making exactly this Excel IF() use case easier in the Channel Calculator.
Brad Turpin
DIAdem Product Support Engineer
(4,667 Views)
Hi Brad,
Thanks for the info, I'm sure it will be a welcome addition to the diadem tools for many users.
Regards
Ade
(4,663 Views)
