DIAdem
csv channel issues
Here's a fun question, I'm working with some files automatically generated files from a machine at work, and I'd like to import the csv into DIAdem. However, it only recognises the first column, due to the header file. Any idea how I can import this through a script with both channels in?
The file looks like this:
Tested by: XXX
591_004_2010-05-11_104458_XXXX.CSV
2010-05-11
1607.85
1002
-9.00001
16685
-1.00,-0.025939
-0.99,-0.025939
-0.98,-0.025939
-0.97,-0.025938
-0.96,-0.025938
-0.95,-0.025937
-0.94,-0.025937
-0.93,-0.025936
-0.92,-0.025936
Thanks!!!
(4,167 Views)
Accepted by topic author xxxtomxxx
Just use the DIAdem file DataPlugin Wizard and create an DataPlugin that matches your format.
Afterwards you can load all files of this type with the plugin.
I attach one that I created with your example data.
(4,156 Views)
If forgot to say before, it works great, brilliant, thankyou so much!
(4,005 Views)
