DIAdem
curve name as label on curve
Hello I would like to do the following in a (2D) report: I have several Y-axes with a common x-axis. On some Y-axes I have to display 2 or more curves, i.e. temp_left and temp_right. Instead of a rectangular area at one corner of the display I'd like to display the curve/channel name on the curve itself. I, till now, did not manage it. Any help? Best regards,
(3,547 Views)
For some curve types like "Line and points", "Special combination", "Constant" and "Coordinate" you can set the "Curve End Label" . Set the "Label" to "Channel name".
Hope that helps
Winfried
(3,544 Views)
