DIAdem
data stored at different rates
I need to align two data sets that have been stored at different rates to enable me to use the CTNV function to clip unwanted data.
Ch("new") = Ch("[1]/z")+CTNV((Ch("[1]/Velocity")<17))
this code clips the altitude (z) data when velocity is below 17, this works fine because both channels were store at 1Hz
Ch("new") = Ch("[1]/A2R1")+CTNV((Ch("[1]/Velocity")<17))
this code doesn't do what I want because strain gauge data (A2R1) was stored at 240Hz and velocity at 1Hz.
I'm sure there is a simple solution (probably several of them) but I'm pretty new to DIAdem and it's got me stuffed!
(4,696 Views)
Hi smiffy,
you can use the analysis function "linear mapping" at the "curve fittings" to bring the 2 channels to the same data rate.
use the time channel from the other channel as "interpolation channel"
regards sven
(4,691 Views)
Hello smiffy!
One keyword for sven's suggestion is 'ChnMapLinCalc'. Look for this command in the DIAdem help or search this forum to get some examples.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,686 Views)
Thank you.
That was too easy!
(4,656 Views)
Thank you very much
(4,655 Views)
