DIAdem
datafinder read properties type "DataTypeDate" from script
Hello All,
What do I need to read "Modify date" property value from my Datafinder resultlist?
result of:
Dim oMyDataFinder, oMyQuery, MyDate, MyMin, oMyResults
  Set oMyDataFinder = Navigator.ConnectDataFinder("My DataFinder")
  If oMyDataFinder.Name = "My DataFinder" Then
                   Dim AdvancedQuery
             Set  AdvancedQuery =Navigator.CreateQuery(eAdvancedQuery)
             AdvancedQuery.ReturnType=eSearchFile
             Call AdvancedQuery.Conditions.Add(eSearchFile,"aaaa","=", "*")
             oMyDataFinder.Search(AdvancedQuery)
             Set oMyResults = oMyDataFinder.Results
msgbox(oMyDataFinder.Results(1).Properties("modifyTime").value)
is err. number 438. "proprietà o metodo non supportati dall.oggetto"
oMyResults.count return 1
 My property value is "11/15/2010 11:08:30".
Yustas
(3,767 Views)
Accepted by topic author Yustas
Hello Yustas,
for date/time properties an object called "UsiTimeDisp" is returned.
To print the date using msgbox please try
msgbox(oMyDataFinder.Results(1).Properties("modifyTime").value,variantdate)
Hope that helps,
Eva
(3,764 Views)
Hello Eva,
it works
msgbox(oMyDataFinder.Results(1).Properties("modifyTime").value.variantdate)
thanks,
Yustas
(3,759 Views)
Hi Yustas,
Note that if you request the DateTimeObject.VariantDate, then you are losing the millisecond and microsecond and nanosecond information stored in the DateTimeObject.  You can alternatively request the entire object and read that info off as properties, if you need it...
Set Prop = ResultsList(1).Properties("DateTime")
Set DateTimeObject = Prop.Value
MsgBox DateTimeObject.Millisecond
Brad Turpin
DIAdem Product Support Engineer
(3,735 Views)
