DIAdem
dataload error
Hi all,
Each time when i run my scxript and load a file , the same file loads from navigator.
You can see the same file imported to data portal marked in red.
 Help me to resolve this ..
(3,553 Views)
Accepted by topic author RSH
Hello RSH,
This is not an error it is a defined behavior in DIAdem. DIAdem has by default a unique group name and channel name condition. That means that the name of a group must be unique in the Dataportal and a channel name must be unique within a channel group. If you load some data that doesn’t fit with that condition DIAdem automatically counts-up the Name. If the end of the name is already a number this number will be count-up. To prevent a misunderstanding of original name and counted name you can choose a separator. You can set this separator in the “General Settings”, “Unique group and channel names”
Greetings
Walter
(3,544 Views)
