DIAdem
dateadd error
I am getting an error
"Calculation result isn"t a channel!"
when I run
Ch(#) := ("DateAdd(h,12,Ch(1)")
from the formula calculator.
I need to offset all time values in Ch1 by +12 hours and store results in next available channel. Dateadd is a vb function and must use the formcalc to execute in an automation.
What must I change?
Jim
(5,097 Views)
Jim,
This formula worked for me:
Ch(#) := ch(1) + 12*3600
Basically, it takes Channel 1 and adds 12 * 3600 ( = number of seconds in 12 hours) seconds and stores the result in channel #.
Hope that helps,
Otmar
Otmar D. Foehner
(5,097 Views)
That suggestion worked very well.
(5,097 Views)
