DIAdem
delete all values of a channel
when i delete all values in a channel in data portal
Call DATABLDEL("/VS_Y",1,Chnlength(3))
it also deletes the name of the channel! how can i avoid this?
thanks in advance
kaan
(3,531 Views)
Hi kaan,
I think the reason is, that DIAdem 'think', if you delete all data of a channel you don't need that channel.
A workaround could be to re-create that channel with ChnAlloc
greets Andreas
Volkswagen AG
Wolfsburg - Germany
(3,520 Views)
It is possible to set the channel length to zero:
Call ChnPropSet(3, "length", 0) ' Set length of channel 3 to zero
This is different from deleting, because usually the values are still there, but not valid anymore. You can get the values back by resetting the length. For normal operations, the channel should behave like a channel with the length of zero.
(3,501 Views)
