DIAdem
delete the default minimum maximum properties
hi
want to delete the minimum &  maximum properties   in diadem channel  -properties  programmatically thr' labview
but I thing that TDMS writes it by default ?
(4,923 Views)
Hey,
the minimum and maximum properties are part of the TDMS data model and you are not able to delete this properties.
Stephan
(4,898 Views)
thanks
(4,891 Views)
