DIAdem
desktop.ddd spec
Anyone has or (know where to get) the specs for DIAdem desktop.ddd file. We need to understand the descriptions of the file's content?
(5,206 Views)
This link might be helpful for a closer look at what the .ddd file contains.  It essentially has a bunch of settings and formatting information that are applied when DIAdem launches:
http://zone.ni.com/reference/en-XX/help/370859J-01/genshell/genshell/genshell_desktop/
Michael Keane
(5,175 Views)
Thanks for the link. However it does not more details for the file's content.
(5,155 Views)
I suppose you could right click and open it with a text editor if you're curious of the format of the actual contents.
Michael Keane
(5,148 Views)
Hello Larry,
just wanted to mentioned that the reason for not documenting the file format is simply that the format is not meant to be a public interface. Even if you find out how its structured now, it may change with the next release. It might help if you could describe why you would want to access the file directly.
Andreas
(5,140 Views)
