DIAdem
diadem fft
Can DIAdem calculate a "live" running FFT on the data channel under analysis while scanning through the data channel in the VIEW menu with the cursor.  I want to be able to pinpoint an event within the test results using its frequency contents in chunks.  I know you can break up intervals in the FFT toolbox to see dominent frequencies but I want to see in real time so I can put the event to the dominent frequency.  I have seen other packages especially in sound that do this.
(3,608 Views)
Hello testworld,
I have attached a complete example (Scripts, layout and data file). Please extract into a any directory, then run the "FFT Window.VBS" file from the Script panel.
The example is easily adaptable to other data files,
I hope that helps,
    Otmar
Otmar D. Foehner
(3,604 Views)
