DIAdem
diadem how to color cells individually
Hi Louval,
Did you finally get this to work? I have a working application (see image) where I color the background of each cell based on the value it contains, and I had many of the same issues you are describing. I'd be happy to walk you through it if you are still not happy with your results.
Message 11 of 25
(4,671 Views)
Hi!
Thank you for your concern. No without fighting hard agaist the machine. It seems I have won.
Cheers,
Message 12 of 25
(4,667 Views)
Looks great! Success feels good, doesn't it?
Message 13 of 25
(4,664 Views)
Congrats!
I've got a whole folder allocated to various user commands for table formatting. Here is a common one that I use for marginal and hard failure criterea.
I still wish you could use property values directly, instead of having to copy them into data channels...
Message 14 of 25
(4,658 Views)
Could you please give me an example of use of this great function of yours?
Louval
Message 15 of 25
(4,353 Views)
Hi, Louval
This looks great. What method do you use to highlight the cell?
Thank you.
Message 16 of 25
(4,227 Views)
Hi, gizmogal,
I like the example you posted and I am trying to color my table cell like this way. I really appreciate your help if you can walk me through this.
By the way, the table cell I have contains text value, such as pass/fail, I want to color fail to red etc. Thanks,
LLX
Message 17 of 25
(4,137 Views)
All,
In my experience, DIAdem 2012+ allows foreground coloring, 2014+ allows background coloring.
As to how to do the coloring, I use the newer Object Oriented methods:
Link the UserCommand subroutine to the column in question:
  Report.Sheets(1).Objects("Table").Columns(1).Settings.OnDrawingCell = UserCommandSubroutineName
Set up your usercommand subroutine to use the cell's value to set the color of the cell based on the value:
Sub UserCommandSubroutineName(Context, Cell)
  Set oCurrColumn = Context.Table.Columns.Item(Context.Col)
  set oSettings = oCurrColumn.Settings
  Set oCurrChannel = Data.GetChannels(oCurrColumn.Channel.Reference)
  if oCurrChannel.Count > 0 then
    CurrText = ucase(Cell.Value)
    Select Case CurrText
    Case "PASS", "OK", "ACCEPTABLE"  'Green
      '"FG"
      'oSettings.Font.Color.ColorIndex=eColorIndexDarkGreen
      '"BG"
      oSettings.BackgroundColor.ColorIndex=eColorIndexOtherColors
      Call oSettings.BackgroundColor.SetFillingColor(RGB(50, 150, 50), RGB(50, 200, 100), eColorGradientVertical, eColorGradientModeFromOutside)
    Case "FAIL", "BAD", "HIGH", "ELEVATED"  'Red
      '"FG"
      'oSettings.Font.Color.ColorIndex=eColorIndexRed
      '"BG"
      Call oSettings.BackgroundColor.SetFillingColor(RGB(255, 50, 50), RGB(255, 100, 100), eColorGradientVertical, eColorGradientModeFromOutside)
    End Select
  end if
end Sub 'UserCommandSubroutineName
You can set up generic subroutines to handle sets of text values, numeric values based on min/max or seperate min/max channels.  I would recommend using a property on the channel do determine which type of coloring and comparison you intent the subroutine to do (so you don't need hundreds of routines).
This code may not work directly because I've cut it out of much more generic scripts and pieced it together here, but the basic principles should apply.
-Josh
Message 18 of 25
(4,046 Views)
To gizmogal:
Your table design is just what I'm trying to achieve without much luck. It's been a while but can you post the code that performs your cell coloring? You'd think by version 2017 they would have solved this with a simple property but not so as yet. Anyway please send a code fragment if you can.
Message 19 of 25
(1,826 Views)
Hi, here is my code for coloring table cells -- pass (green), fail (red) . I used DIadem 2014. This is the function to generate overalltable and call cell coloring function. in this function 't' is the result count, fox example I have 240 results to be listed in table, each table page has 30 rows, then totally 8 pages table will be auto generated.
function CreateFailTables(ReportFilePath,t)
Dim i, iMax
iMax = (t+5)/NumTableRows
iMAx = int(iMax)+1
Call WndShow("REPORT")
FOR i = 1 TO iMax
Call PicFileAppend(ReportFilePath)
Call GraphSheetInfos()
Call GraphSheetNGet(GraphSheetCount)
Call GraphSheetRefSet(GraphSheetName)
Call GraphSheetRename(GraphSheetName, "Pass Fail " & i)
Call GraphObjOpen("2DTable1")
D2TabAutoScalTyp = "fixed"
D2TabBegin = 1 + (i-1)*NumTableRows
D2TabEnd = i*NumTableRows
D2TabNoDist = 1
Call GraphObjClose("2DTable1")
Report.Sheets("Pass Fail " & i).Objects("2DTable1").Columns(1).Settings.OnDrawingCell = "TabPassFailOnDrawingCell"
Report.Sheets("Pass Fail " & i).Objects("2DTable1").Columns(10).Settings.OnDrawingCell = "TabPassFailOnDrawingCell"
Call PicUpdate
NEXT ' i
End function ' CreateFailTables()
''this is cell coloring function, based on cell value to color.
Sub TabPassFailOnDrawingCell(Content, Cell)
Dim CurrVal, oSettings
Set oSettings = Content.Table.Columns(1).Settings
Set oSettings1 = Content.Table.Columns(10).Settings
Set oSettings2 = Content.Table.Columns(2).Settings
CurrVal = Cell.Value
If Trim(UCase(CurrVal)) = "PASS" Then
oSettings.BackgroundColor.ColorIndex = eColorIndexGreen
oSettings1.BackgroundColor.ColorIndex = eColorIndexGreen
oSettings2.BackgroundColor.ColorIndex = eColorIndexGreen
ELSEif Trim(UCase(CurrVal)) = "FAIL" Then
oSettings.BackgroundColor.ColorIndex = eColorIndexRed
oSettings1.BackgroundColor.ColorIndex = eColorIndexRed
oSettings2.BackgroundColor.ColorIndex = eColorIndexRed
ELSEif Trim(UCase(CurrVal)) = "" Then
oSettings.BackgroundColor.ColorIndex = eColorIndexNone
oSettings1.BackgroundColor.ColorIndex = eColorIndexNone
oSettings2.BackgroundColor.ColorIndex = eColorIndexNone
ELSEif Trim(UCase(CurrVal)) = "NULL" then
oSettings.BackgroundColor.ColorIndex = eColorIndexYellow
oSettings1.BackgroundColor.ColorIndex = eColorIndexYellow
oSettings2.BackgroundColor.ColorIndex = eColorIndexYellow
ELSEif Trim(UCase(CurrVal)) = "Incomplete" then
End If
End Sub ' TabPassFailOnDrawingCell()
Message 20 of 25
(1,823 Views)
