DIAdem
diadem report error <BarSourceDyn.VBC> (line:136, column7):
I am trying to export 6 slides to a ppt. What does this error mean?
(5,008 Views)
WRX,
Does this error come up if you try to export any slides to powerpoint or do you only get this error if you try to export these slides in particular?
(4,972 Views)
Matt,
Only these slides. I just tried a different one and it worked fine.
(4,957 Views)
Wrx,
Can you try to export each slide individually?  If you find that one or a few slides give you this error can you try copying each object to a blank slide and exporting a single slide with a single object.
If you do this by copying each slide and pasting it into an entirely new worksheet we can hopefully find out what objects are throwing this error to give us a little more context.
(4,936 Views)
hmmm. I am not sure what changed over the weekend but it is working now...
(4,908 Views)
