DIAdem
diadem unit convert
I am trying to convert the unit of a channel into another different physical unit , but diadem only replaces  the unit symbol and the value remains the same. Is it possible to change the unit symbol as well as the value at the same time , thanks!
(5,335 Views)
Yes..it is possible..!!! I have used it several times. You have to click "Convert" (if you are not doing that already).
In any case, select the channel > click on Unit (in properties) > select new unit > Click Convert. It is as simple as that. I am not sure what happened on your PC. Maybe if you can tell more about how you are doing it, I could help.
(5,330 Views)
