DIAdem
diadem
You answer was great! thank you very much.
i have another question , on this system ( picture attached), how can i stop the system after 10 sec working ( after the push) ?
Thks!!!!!
Message 11 of 15
(3,143 Views)
Calculate the number of values which will be acquired in 10 seconds. With a clock rate of 100 Hz this is:
100 values per second * 10 second = 1000 values
Greetings
Walter
Message 12 of 15
(3,128 Views)
ok, and if i want to choose the timer value with a slider control for example ?
Message 13 of 15
(3,120 Views)
The number of values in the save block is absolute exact. If it doesn't matter whether you acquire 10 s or 10.05 or 10.1 second you can choose every other trigger which stops the measurement - like stop the save block (no retrigger), stop the clock block. How to define the trigger is up to you.
Greetings
Walter
Message 14 of 15
(3,116 Views)
i just want to have a controller which could define the time period of the mesuration.
Message 15 of 15
(3,114 Views)
