DIAdem
diadem
Hello everybody,
Someone know how to connect DIADEM With EXCEL ? For transfer a data value for example.
Thks
Kind regards
(6,170 Views)
you can use a shipped example from DIAdem:
Beispiele > Scripte erstellen > Schnittstellen verwenden > Clientbetrieb von DIAdem mit Excel als Server
Examples> Create Scripts > Use Interfaces > Client use of DIAdem with Excel as server
You can also use the TDMS Import Plugin for Excel:
TDM Excel Add-In for Microsoft Excel Download - National Instruments
http://www.ni.com/example/27944/en/
Regards, Stephan
(6,155 Views)
Thanks for you answer
That's work with DAC Program ?
Antoine
(6,148 Views)
DAC Program?
A little bit mor information would be useful.
(6,145 Views)
picture attached
(6,142 Views)
Hi Antoine,
Modern versions of DIAdem create TDM files when running a DAC scheme.  TDM files can be loaded into Excel by right-clicking on them and selecting the context menu "Open with >> Excel Importer".  This TDM Excel Add-in is installed by DIAdem and many other NI software packages, and it can be downloaded for free to any computer.
Brad Turpin
DIAdem Product Support Engineer
(6,133 Views)
