DIAdem
error when save a file as .wav format
I was trying to save some sound pressure data into .wav file.  I have a single wavform channel looks like this:
before
Once saved as .wav file, the data becomes:
What did I do wrong?
(5,296 Views)
I do have the audio data plugin installed, but I do not know how to use it.  The save as give me the same results before and after the installation.
(5,293 Views)
The *.wav file specification says that the DBL data type may only be used if all the channel values are between -1 and +1.  That channel exceeds these limits slightly, therefore an integer data type is used.
You can simply rescale the channel prior to saving-- either smaller in amplitude to use the DBL data type or larger in amplitude to use the full range of an Int16 or an Int32.
(5,267 Views)
Thanks!  I scaled the data up to use the 32 bites integer.  It worked!
(5,251 Views)
