DIAdem
extern sampling rate DAC...how to
Hello to all DIAdem-pro´s!
My Englisch is not so good, so please excuse wrong words or expression.
I have a problem: I want to apply an incremental encoder with 1000 impulses/cyc on a test rig as an extern sampling rate encoder. I use DIAdem 11 and a Goldammer light USB measuring board. I have already change to "Extern rate" in the Sampling rate brick of DIAdem DAC.
My question: How to configurate the measuring board. The board have to know, from which channel the signal comes and how to transfer this extern signal. Did anyone know this measuring board, or did this board not support this funktion?
boardname:              Goldammer light USB
fabricationname:       MLPUSB
fabricationnummber: 2003-G0A-1024-7-0207
Plaese send me all your ideas, also if they didn´t solve the problem completely. I´m very happy for any idea or different minds. And if the problem is´t clear, plaese ask me to answer it, I´m new here.
Thanking you in anticipation...
Jan Giese
(3,594 Views)
Please follow this Link.
(3,583 Views)
