DIAdem
filer using user properties in DIAdem
I added to my channels some user properties which values clarify the context of different channels, saving all channels in different TDM files. Working woth data loaded in the Data Portal or selecting dat for loading I would like to view / compare /process data with specific values of user properties. How can I filter my channels using User Properties content ?
Luca
(4,000 Views)
Hello Luca,
This should be pretty easy.
In the NAVIGATOR, selected the"Advanced Search" button (little blue icon on the top right side of the NAVIGATOR Window).
Build the query based on your customer property (in your case a Channel property) in the query builder. If you have numeric properties, you can use ">" "<" ">=" "<=" and "=" for your queries. Queries can be connected with AND or OR, it should be pretty straight forward from there.
Let us know if you have any additional questions. If you do, it always helps to share your version of DIAdem and a few data files if you can.
    Otmar
Otmar D. Foehner
(3,992 Views)
Accepted by topic author LG
Hello Otmar,
thank you for your help.
Working with Navigator Advanced Search seems the right way to load in Internal Data workspace exactly what I want from TDM files.
I understand that to further filter channels yet in Internal Data workspace  (using User Properties) i have to add new criteria in Advanced Search form!
Luca
(3,946 Views)
