DIAdem
filex variables
How do I include variables with * commands in a filex command, written within a SUD?
I am using the filex command to search for a specific file name, and I would like to include a T2 variable with some wildcards.
The T2 variable has been defined by another SUD
What is the correct syntax?
  If FilEx("D:\New_PC\Testing\New Rig\data\*(T2)*.txt") Then
If the outcome is true then I load the file,
Filepath.Text = FileDlgname
  Call AsciiLoad(filepath.text, 0)            '{Import}
If false then a say that it does not exist.
(4,115 Views)
Hello!
Try this:
If FilEx("D:\New_PC\Testing\New Rig\data\" & T2 & ".txt") Then
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,108 Views)
Thanks vey much.
I still would like to return the name of the file and load it into the data portal.
Does Fileex return a variable other than TRUE or FALSE?
Is there a better way to search for a file with that variable in its title and load it.
The variable only contains the middle part of the file name.
ie file name = mydata220207.txt
I would like to search for all files with 220207 and then load it.
(4,091 Views)
Hello Stagsden!
As far as I know is there no pure DIAdem solution. My aproach is to get all files of a folder with the file system object and make the wildcard compare with the regular expression object.
The example code:
Option Explicit
Dim oFSO
Dim oFolder
Dim oFile
Dim oRegExp
Dim sgPath
Dim sgMask
' Input parameter
sgPath = "D:\Programme\National Instruments\DIAdem 10.1\Libr\Dat\"
sgMask = "E*.tdm"
' Get the folder via the file system object
Set oFSO    = CreateObject("Scripting.FileSystemObject")
Set oFolder = oFSO.GetFolder(sgPath)
' Get the regular expression object and convert wildcard string to regular expression
Set oRegExp = CreateObject("VBScript.RegExp")
oRegExp.IgnoreCase = True
oRegExp.Pattern    = "^" & replace(replace(replace(sgMask,".","\."),"*",".*"),"?", ".") & "$"
' Loop through all files and show a message box for every match
For Each oFile In oFolder.Files
  If oRegExp.Test( oFile.Name) Then
     MsgBox oFile.Name
  End If
Matthias
Matthias Alleweldt
Twigeater?
(4,083 Views)
Hello Stagsden!
It is always a good idea to put useful code in a function. Here is the optimized version.
Function (result with full path in a string array):
' VBS Dir, Result as string array
Function Dir(ByRef sgPath, ByRef sgMask )
  Dim oFSO
  Dim oFolder
  Dim oFile
  Dim oRegExp
  Dim asgFiles
  ' Prepare result array
  asgFiles = Array()
  ' Loop through all files and add it to the result array
        ReDim Preserve asgFiles(UBound(asgFiles)+1)
        asgFiles(UBound(asgFiles)) = oFile.Path
    End If
  ' Result
  Dir = asgFiles
End Function
Test script:
Option Explicit
Dim sgFile
Dim asgFiles
asgFiles = Dir("D:\Programme\National Instruments\DIAdem 10.1\Libr\Dat\", "E*.tdm")
For Each sgFile in asgFiles
  MsgBox sgFile
Matthias
Message Edited by Twigeater on 02-28-2007 08:16 AM
Matthias Alleweldt
Twigeater?
(4,079 Views)
