DIAdem
filter using max min limits for channel
hii,
I have a channel with temperature values, but the sensor has issues and it gives  sometimes 2^16 as max value.
I want to filter this value from my channel , but did not find Analysis tool where I can filter based on  Limit.
is there any way to set the max or "in range " Limit for a channel  in the Analysis tool set.
regards
Akshay
(2,855 Views)
Hi aparab,
You can use the channel event functions in ANALYSIS.
Condition fulfilled is the original channel and condition not fulfilled is NoValue or any other value
Lower limit = NoValue means all values below the upper limit
Greetings
Walter
(2,831 Views)
thanks a lot, Walter
regards
Akshay
(2,807 Views)
