DIAdem
font size of legend of Visual objects
I think the font size of the legends in Visual objects is too small. I haven't found a possibility yet to change it and NI support also says it's not possible. Does somebody know a workaround?
(I'm not talking about the font size of the measured values, of course, that'd be easy!)
Regards
G.S.
(3,419 Views)
Unfortunately I just can confirm what the support told you before. There is no workaround except you add a graphic (WMF file) to your DAC scheme.
But I will add your suggestion to the list of further DIAdem functions maybe that have it in one of the next DIAdem versions.
Greetings
Walter Rick
(3,419 Views)
