DIAdem
frequency response function
Hello Everybody,
I want to calculate a frequency response function out of a acceleration and force signal. I measured this signals with an sinus sweep function from 1- 1000 hz.
Is there a way in diadem to solve this problem?
Thank you for your help!
Bye Vincent
(5,071 Views)
Hi Vincent,
sure, you can use the FFT bloc (Analyze >> Signal Analysis >>FFT) and select the channel you want to use.
I hope this helps.
Marc
(5,047 Views)
