DIAdem
hOW TO LOAD ASCII FILES
I AM TRYING TO LOAD AN ASCII FILE .. While loading it from navigator ascii import wizard window is opening. I do not know what is that *.stp file and what parameters i should specify in atep 2 and 3. Also is it necessary to download ascii data plugin for this??
Am selecting Ascii import (*.*, *.csv,*.asc,*.txt, *.dat) from data load window.
Plz help me to do this..
(3,479 Views)
Please give an impression how your ascii file is build up.
Or post an example.
In additional you can try the "DataPlugin Wizard" in the filemenue.
If your file can be accessed by the default reader the wizard will generate
a DataPlugin that can be used each time this kind of file should be loaded.
The ascii import wizard is the old approach to import text files.
The stp file stores the configuration of the old wizard.
(3,463 Views)
