DIAdem
highest sampling rate supported in DIAdem
Dear Sir:
I use DIAdem and DAQ6062E to acquire data. the problem is that the highest sampling rate is only 1000/second even the Default Clock had been set to 10000/second and higher. would someone like to give me any suggestion to solve the problem?
jing
(3,192 Views)
Hi Jing,
You can set the clock rate in DIAdem DAC by using the block "system clock" (first toolbar, looks like a yellow metronome). If you double click it you have several settings (it depends on the hardware which settings you can use). For NI hardware you can set ->"DAC kernel" -> "Hardware clock" and "Clock rate". Than you must connect the (yellow) block output with the corresponding input (yellow icon) of all other blocks (which require this connection) in your DAC scheme.
I hope this can help you
Greetings
Walter Rick
(3,184 Views)
