DIAdem
how to acquire data in DIAdem with DAQCard6062E
I found data acquisition in DIAdem is very convenient and usful, whereas I've no idea of how to build such a flow chart in DIAdem to acquire data with DAQCard6062E. Will some one please give me some information.
thank you very much
(3,553 Views)
Hi jingli,
The way to acquire data is the same for all NI DAQ boards, so what I am describing can be used for other hardware, too.
First you need to create virtual channels in Measurement and Automation Explorer.
This KB tells you more about that:
http://digital.ni.com/public.nsf/websearch/31C55E253B023189862569850068B8AE?OpenDocument
After creating and configuring those virtual channels you can use them in DIAdem DAC. Simply use a NI-DAQ Input block. When you open it's configuration dialog (double click), you can see two lists of channels. On the left you can see all the channels you created. Add the channels you want to acquire to the list of selected channels on the right and click OK.
That's it. Now you can acquire from your NI-Hardware. In m
ost cases you will want to use a Clock block with hardware timing, so you can really use the acquisition speed the hardware provides.
Richard H.
(3,553 Views)
Dear Richard:
Thank you very much for your help. your suggestions realy do the jod.
yours
jing
(3,553 Views)
