DIAdem
how to call a function with parameters in ScriptStart function
i am trying to call ScriptStart function from SUD dialog. This is how iam calling Call ScriptStart(path & "test.vbs","abc") abc is function which is written test.vbs. It is working. But when i want to pass some parameters to the abc function of test.vbs. It is not working why. can anybody suggest where i went wrong. I am calling the same function as Call ScriptStart(path & "test.vbs","abc(" & text1.Text & ")"). It is not working why ? Is the ScriptStart function only point to functions. it does not take any parameters or waht ?
(8,606 Views)
This is correct, the second parameter of the scriptstart command is to call procedures, not functions. It does not support the transmission of parameters to a subroutine.
I would recommend to use usercommands, here you may pass parameters.
Ingo Schumacher
(8,606 Views)
Hi abc421,
Another option in addition to UserCommands would be to use ScriptInclude(path). If you execute a ScriptInclude(path) command at the beginning of your VBScript, then all the functions and Subs in the VBscript located at "path" are now available to you-- including passing parameters and receiving return values from functions. If you are calling a VBscript that uses only VBScript variables, then this is the preferred method.
If instead you are calling a VBScript that uses global DIAdem variables declared in a VAS file (their variable names all end with the "_" character), then those parameters are already available at the subroutine called with ScriptStart(path, routine).
Brad Turpin
DIAdem Product Support Engineer
(8,606 Views)
