DIAdem
how to choose proper filter for my specific applycation
hello everyone,
        I have acquired pressure  data from anolog module  of cDAQ chassis 9172. The thing is the signal doesn't start from zero and the start point is change for each running and this is acceptable for our experiment. I try to filter the data with filter express VI but seems it always begins from zero. I'm not familar with data filtering stuff  but i still want to know is there any filter i can use that  just filter data without from zero.
Thanks in advance.
Zhiqin
(4,144 Views)
Hi Zhiqin
Im not sure if I understand with the term " try to filter the data with filter express VI but seems it always begins from zero." could you perhaps explain that a little bit more in detail.
/Bjorn
(4,046 Views)
Hi Zhiqin
Are you using DIAdem or LabVIEW to do the digital filtering?
Brad Turpin
DIAdem Product Support Engineer
(4,031 Views)
