DIAdem
how to generate PDF reports one by one by Diadem script
Hi: All
     I a new learner for diadem, with one excel file with 3 original force/stroke curves data, now, I want to write one script, load the excel file, generate the PDF formats one by one automatically.
     someone who can help me, pls mail me directly by email address(jack.zhao1@trw.com), TKS a lot!
(2,685 Views)
I am interested in this topic too.
If you find a solution, please share with the community 🙂
(2,618 Views)
Hi Jack,
I can help you create a DataPlugin that will read your 3 strokes into 3 different Groups in the Data Portal.  Then you can loop over the loaded Groups and send each one to a separate PDF file.
Is this one *.xlsx file the exact same format as all your others that you want to report?  Is there really a "curve_N" row at the top of all your files, or was that inserted for NI's benefit?  Do you always have 3 strokes, or might you have only 1 or 2 or even 10 organized left to right with no empty columns in between?
Brad Turpin
Senior Technical Support Engineer
(2,546 Views)
