DIAdem
how to get channel values to store in a new one
i have some empty channels, like Temperature. I also have a lot of TDM files, every TDM hat a temperature channel(only one data),
so the temp datas from different TDM files should be collected to  the channel Temperature one by one. Is there any founktions or anything else can help? Thanks a lot.
Best Regards
Jiayi You
(4,779 Views)
Hi Andreas,
please have a look at the
Concatenate Channels
Example in DIAdem 2012.
Regards
Stefan
(4,778 Views)
Hi Stefan,
thanks, i will check it out.
Best Regards
Andreas
(4,776 Views)
Hi Stefan,
the ChnConcat can be used between different TDM datas?
Best Regards
Andreas
(4,771 Views)
