DIAdem
how to link combo box(drop down) and SQL(database values)?
how to connect to SQL and show the result in the drop down?
 Dim myHWSETConn,myHWSETCommand,HWSETRS
  HWsetSelection = val(HWsetSelection)
 Const DB_CONNECT_STRING1 = "Provider=SQLOLEDB.1;Data Source=FWATRGSQLVCL2;Initial Catalog=Cal1;user id ='Caluser';password='caluser'"
  Set myHWSETConn = CreateObject("ADODB.Connection")
  Set myHWSETCommand = CreateObject("ADODB.Command" )
  myHWSETConn.Open DB_CONNECT_STRING1
  Set myHWSETCommand.ActiveConnection = myHWSETConn
  myHWSETCommand.CommandText = "SELECT [hw_fullname] FROM [Cal].[dbo].[Req_Simple] where Fwid= "&HWsetSelection&" "
   Set HWSETRS = myHWSETCommand.Execute
I have this code which fetches the values from SQL but i am having trouble putting them on to dropdown, i tried
 call NewHwset.Items.Add(HWSETRS)
but it says, type mismatch "NewHwset.Items.Add"
Any help is highly appreciated,
Thank you.
(4,336 Views)
Kandukuri,
Are you able to see the values at all from the SQL database? I mean, outside of trying to put them in a drop down, can we read them at all?
Michael Pahl
Technical Support  Engineer
(4,295 Views)
dim HWSETRS : Set HWSETRS = myHWSETCommand.Execute
if NOT (HWSETRS.BOF or HWSETRS.EOF) then
  dim columnValues : columnValues = HWSETRS.GetRows(-1, 0, 0)
  dim columnValue : for each columnValue in columnValues
    call NewHwset.Items.Add(columnValue)
end if
something like this might work.
For further information you need to check the ADO recordset documentation.
https://docs.microsoft.com/de-de/sql/ado/reference/ado-api/getrows-method-ado?view=sql-server-2017
https://www.w3schools.com/asp/ado_ref_recordset.asp
(4,288 Views)
yes@Michael Pahl
HWSETRS
this object is holding the result, i tried showing them in the msg box, it should actually return 2 records but its returning one, so the connection does work, may be i need to make few modifications for it to show both the records.
(4,280 Views)
what does 'column value' doing here?
(4,277 Views)
@ AndreasK
its throwing the error saying"argument not optional:NewHwset.Items.Add"
(4,271 Views)
I am not sure which Add method you are using.
Please check the help for it.
If it is an ItemList
  dim nrVal : nrVal = 1
    call NewHwset.Items.Add(columnValue, nrVal)
    nrVal = nrVal + 1
might work.
(4,262 Views)
