DIAdem
how to parse a text file into data base using VBS
Hi all,
i have a text file with a line of more than 1000, which contains information about the user name and password etc. i want to write a script to parse my text file into a Data Base using DIAdem. i don't have any work experience in VBS or DIAdem. can any one please guide me on this.
Thanks in advance for your reply.
Shruthi,
(4,456 Views)
Hi Shruthi,
Actually, DIAdem doesn't give you any functionality for this task that you don't already have with a VBScript running in the Windows Scripting Host.  You can use the built-in FileSystemObject to open the text file, the Split() command to parse out the values left to right, and the ADO object to open a connection to the data base and insert the new records.
Brad Turpin
DIAdem Product Support Engineer
(4,441 Views)
