DIAdem
how to remove the character "1" next to x-axis of diadem report?
In the report graph generated by Diadem, there is always a character "1" next to the x-axis lable. Can anyone tell me how to remove it?
Please refer to the attached the picture (lower-right corner).
(3,849 Views)
Accepted by topic author chenfangzhi
Hi, this has to do with the scaling and formating you are using. If you are using an automatic Scaling mode and you X-values have the display format "Time", DIAdem switches to the scaling type "Date/Time". By default, DIAdem is using an automatic formating with two lines. The upper is for the Ticks and the lower for a larger step. It looks as if your time-data is only holdig the seconds of the day, but not the date itself. So DIAdem assumes a year 0 and the 1 is for the first day of the year. If your data spans over several days, you will see the number of the day below the 12:00 for each day. Depending on the X-values, the automatic scaling will show seconds, minutes, hours or dates and years. You just need to go to the X-Axis - numbers tab and change the format. "#hh:nn" would do the job with leading zeros and "#HH:nn" without leading zeros.
(3,843 Views)
