DIAdem
how to return the row number of a channel data point
I'm new to DIAdem and I'm struggling a little.  I'm trying to do something relatively simple I think but I haven't been able to figure it out.  How do you get the row number of the maximum value in a channel.  I see how to get the maximum value from the maximum channel property.  how do I get the row number?
(4,416 Views)
Hello chiligog,
Here's the code that returns the row number:
'Row = PNo(ChNum, CMax(ChNum))
L1 = PNo(2, CMax(2))
msgbox(L1)
Function: PNo
Determines the row in a numeric channel or a text channel, of which the contents are closest to a specified value or text.
ReturnValue = PNo(ChannelName,Value)
If you have the Crash Analysis Module for DIAdem, there is an easy way with the Min/Max function:
But since most people don't have that module, the first solution i posted is perfectly capable ...
That should do it. Let us know if you have additional question ...
     Otmar
Otmar D. Foehner
(4,413 Views)
yes that was exactly what I was looking for.  thank you
(4,405 Views)
