DIAdem
iif ssems to evaluate allways both parameters, the true AND the false case
trying the new IIF command I'm a little surprised. Run the following code:
Dim a,b
a=1
b=3
logfilewrite(IIF(a>0, b/a, a/b))
a=0
b=3
And you'll get an division by 0 error in the second case.  But that's exactly what I would like to prevent with this IIF statement.  This example is not verry usefull but there are many cases where this behaviour leads to trouble. Like in the following "usefull" line of code:
logfilewrite(IIF(RootPropExist("MyProp"),RootPropValGet("MyProp"),"DefaultValue"))
Has anyone a workaround keeping this an inline statement?
Best Regards
Martin Liese
(5,034 Views)
Accepted by topic author mliese
Hello Martin!
IIF is like any other VBS function calls. All paramters are evaluated before the function is called. In general it is OK in the case of IIF it is sometimes annoying. The solution is to build your own IIF equivalent function:
Public Function IIFX( ByRef Compare, ByRef FalseExpr, ByRef TrueExpr )
  If Compare <> 0 Then
    IIFX = Eval(TrueExpr)
  Else
    IIFX = Eval(FalseExpr)
  End If
End Function
The drawback is the you have put the false and true expression in a string. Bad to read and sometimes a little difficult to write. Your example has to bechanged to:
logfilewrite(IIFX(RootPropExist("MyProp"),"RootPropValGet(""MyProp"")","""DefaultValue"""))
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(5,016 Views)
For anyone finding this question from google, I had a similiar problem with this solution. http://www.adamjamesnaylor.com/2012/10/29/SQL-Server-Reporting-Services-IIf-Function-Evaluating-True...
(4,319 Views)
