DIAdem
import excel file on diadem
Having trouble loading or importing excel files on data portal(Diadem)
(2,909 Views)
What kind of trouble?
(2,886 Views)
This is what I am seeing when trying to load excel data file on diadem data portal.
(2,804 Views)
The long path is concerning to me.
Please try to move file to a much shorter path location. like c:\user\public\test\<File name.xlsx> and retry.
Just a note. When I have read a Excel file into portal, usually this requires a custom dataplugin. This is due to the formatting for Excel files being very custom, and requires the dataplugin to know the format well.
Do you have a example excel file that you could post?
Paul
(2,775 Views)
I am currently using base version of diadem 2019. I noticed that my version doesn't support "excel dataplugin wizard". please suggest some alternative to load excel data on data portal on diadem. please check the attached sample excel file that I am trying to read on diadem.
(2,724 Views)
Hi Krishna,
I created a DataPlugin to read the *.xlsx data file you sent in.  You just need to double-click this *.uri file on the computer that has DIAdem in it, then you will see "Krishna_XLSX" as a DataPlugin option in the File>>Open menu of the NAVIGATOR in DIAdem.  If you have no other Excel DataPlugins registered, you should also then be able to just drag&drop the *.xlsx files into the Data Portal, either from the NAVIGATOR tree view or directly from Windows Explorer.
Brad Turpin
Principal Technical Support Engineer
NI
(2,695 Views)
