DIAdem
infinite loading of diadem autorun on Windows 10 boot
when I boot diadem is autorun and Loading continues
It is normal to run again after forcibly shutting down.
So I tried to turn off autorun, but it wasn't in autorun settings
How can I disable it from booting?
(2,030 Views)
Hi dotheg2e,
DIAdem does not have an autorun feature built into it.  You must have DIAdem configured to automatically start in Windows.  I'm not the best person to ask about all the ways you can configure an application to automatically run in Windows, but here is a support link I found.  Hope it helps.
https://support.microsoft.com/en-us/help/4026268/windows-10-change-startup-apps
Brad Turpin
Principal Technical Support Engineer
(1,972 Views)
