DIAdem
input ascii file to diadem with ascii-import filter
i want to import an ascii-file to diadem7.02 and want to save it as an .DAT-File.
i do this with Fileload and with the ascii-import filter. My problem is, when i want to record a autosequence, and i open the ascii-import filter und push the Ctrl-A key, it doesn´t record this window in the autosequence.
Is this unpossible in DIAdem or have anyone a solution for it.
(4,770 Views)
Hi Bob,
You can programmatically control the ASCI Import Wizard. Here is the sequence of commands to do so:
ShowDialog = 0 ' 0=No, 1=Yes
Call AsciiAssocSet(AsciiFilePath, AsciiSTPFilePath) ' assign the STP file
Call AsciiLoad(AsciiFilePath, ShowDialog) ' load the ASCII file
Call AsciiAssocDel(AsciiFilePath) ' decouple the *.STP from this file extension
Give that a try, and please do ask again if you have additional questions.
Brad Turpin
(4,770 Views)
Thank you Brad for your help,
but this solution is only for Diadem 8 and i have version 7.02.
I have hardly experience in Diadem 8 and nothing in vbs-programming so i had to solve this problem in Diadem 7.
(4,770 Views)
Bob,
You're quite right. With version 7.02 you only have the option of Autosequence code (*.AUT), and I sent you a VBScript snippet. It sounds like you've already changed the syntax, but just in case, and perhaps for any others listeneing in who also want the (*.AUT) syntax, it's:
L1:= 0; {0=No Dialog, 1=Show Dialog}
AsciiAssocSet(AsciiFilePath, AsciiSTPFilePath); {assign the STP file}
AsciiLoad(AsciiFilePath, L1); {load the ASCII file}
AsciiAssocDel(AsciiFilePath); {decouple the *.STP from this file extension}
Brad Turpin
(4,770 Views)
